Hostid and Dongle Support
Altair supports a subset of the available Hostid values from X-Formation as well as hardware dongles (USB keys) on some platforms. In order to use a dongle, you must have an open USB port.
Hostid
- ETHERNET
- DONGLE
- HARDDISK (this is NOT the same HARDDISK value as used by FLEXlm)
- LONG
When requesting a license file, use one of the above Hostid values, and the Altair provided utility, almutil, to obtain your Hostid.
USB Hardware Keys (Dongles)
In order to use a dongle, you must have a free/open USB port on the machine that will be your license server.
- Windows
- Linux
In order for the dongle to function properly, you must first install the correct drivers for your platform. These drivers are available from X-Formation. Download and install the driver from the following URL:
http://www.x-formation.com/lm-x_license_manager/enduser_downloads.html
If that is not available, try
http://www.safenet-inc.com/support-downloads/sentinel-drivers/
and look for the “Sentinel Drivers” for your platform
Once the driver is installed and the dongle is in place, use the almutil –hostid command to query for all the Hostids on the machine and report the DONGLE Hostid.
Other Notes
The user that the license server runs as must have a home directory.
