Web Interface
Some features of the Accelerator web interface can be configured by the administrator. Configuration for these items is performed in the vnc.swd/config/web.cfg file. The complete list of customizable items is shown below.
### NODE VIEWER SETTINGS
#### Use a select (drop-down) menu for priority-based retrace controls
# Set to 0 to disable, set to 1 or comment-out to enable (default)
# set nodeviewer(retraceSelect) 1
# Use a select (drop-down) menu for preemption controls
# set nodeviewer(preemptSelect) 1
