SDS Configuration
- SDS configuration directory, at the server working directory (SWD)/config/publishers/sds, for example, ../vnc.swd/config/publishers/sds
- SDS configuration file in the SDS config directory, sds.cfg
enabled = 0;
kafka_servers = "";
format = "json";
site = "";
group = "";
events = [
project = [
schemaId = 0;
topic = "vov-projects";
taskers = [
schemaId = 0;
topic = "vov-metrics-taskers";
jobs = [
schemaId = 0;
topic = "vov-metrics-jobs";
scheduler = [
schemaId = 0;
topic = "vov-metrics-scheduler";
Configuration File Parameters
Parameter | Values | Default | Description |
enabled | 0 or 1 | 0 | Disable/enable SDS on startup/readconfig |
format |
"json" "confluent" |
"json" | Specifies the Kafka payload format to use, "confluent" = confluent Avro dialect with the schema registry id |
site | string | "" | User definable string to be delivered with the project record |
group | string | "" | User definable string to be delivered with the project record |
debug | 0 or 1 | 0 | Disable/enable SDS debug logging on startup/readconfig |
Event Specific Configurable Parameters in sds.cfg
Each event has its own configuration section in the config file, for example, for the project event:
events = [
project = [
schemaId = 0;
schemaId | integer | 0 | N < 0, do not publish this event N = 0, publish using single object encoding N > 0, publish using Confluent encoding where N is the schema's registry id |
topic | string | see event table | The name of the Kafka topic to which these events are published. |
format |
"" "json" "confluent" |
"" | Overrides format for this event "" = use format specified at the overall service level |
Change the Config File for the First Time
In order to use SDS for the first time, the user must perform the following operations:
Set the kafka_servers parameter in the
sds.cfg file to the bootstrap server(s) for their kafka
installation; for example,
kafka_servers = "kafkahost:9092"
orkafka_servers = "kafkahost1:9092,kafkahost2:9092"
If publishing using the Confluent Schema Registry, then the following steps are
also needed:
- Upload the schema files to the schema registry and note the IDs assigned to each schema.
- Assign the schema registry IDs discovered in step 1 to the events in the sds.cfg file (see Event specific configuration below)
For the initial release the Kafka published events are:
Event Name | Description | Schema File | Default Topic |
project | (relatively) Static project information that may be useful to join with time series data | vov-projects | |
taskers | Metrics related to the state and capacity of the taskers | metrics.taskers.avsc | vov-metrics-taskers |
jobs | Metrics related to the number of jobs in specific states and rate of dispatch/completion | metrics.jobs.avsc | vov-metrics-jobs |
scheduler | Metrics related to scheduler performance, sizes, clients, innerloop timers | metrics.scheduler.avsc | vov-metrics-scheduler |
Changing the Config File at Run Time
The SDS configuration may be changed while the server is running.
Troubleshooting
%3|1610382360.585|FAIL|rdkafka#producer-1| [thrd:foo:9092/bootstrap]: foo:9092/bootstrap: Failed to resolve 'foo:9092': Temporary failure in name resolution (after 1033ms in state CONNECT)
%3|1610382360.585|ERROR|rdkafka#producer-1| [thrd:foo:9092/bootstrap]: 1/1 brokers are down
%3|1610382363.544|FAIL|rdkafka#producer-1| [thrd:foo:9092/bootstrap]: foo:9092/bootstrap: Failed to resolve 'foo:9092': Temporary failure in name resolution (after 993ms in state CONNECT, 1 identical error(s) suppressed)
If the kafka servers are not running or reachable, the server log will contain entries like the following:
%3|1610383215.659|FAIL|rdkafka#producer-2| [thrd:hecto:9092/bootstrap]: hecto:9092/bootstrap: Connect to ipv4#127.0.1.1:9092 failed: Connection refused (after 0ms in state CONNECT, 1 identical error(s) suppressed)
