Speed up nc run
The overhead in the nc run commands consists mostly in the on-demand compilation of Tcl code and secondarily on the number of round-trips to vovserver.
% mkfifo /tmp/vovfifo$USER.$$
% nc - < /tmp/vovfifo$USER.$$
% echo run hostname >> /tmp/vovfifo$USER.$$
- NC_URL: This is the main URL for the vovserver and is used to compute the full URL for each submitted job. If not defined, the code in nc run needs to query the server about the HTTP server name and the WEB port.
- NC_DEFAULT_JOBCLASS: This is the name of the jobclass to be invoked
by default. It can be set to the empty value. This is supposed to have the
same value
as
`vovprop GET 1 NC_DEFAULT_JOBCLASS`
- NC_VALID_DIRECTORIES: The value is a list of directories from which it is acceptable to submit
jobs, all in addition to directories that contain the
.vnc file. It can be set to the empty value. This
is supposed to have the same value
as
`vovprop GET 1 NC_VALID_DIRECTORIES`
# Fragment of the setup.tcl file
# Used to speedup nc run
setenv NC_URL https://nchost:6271
setenv NC_DEFAULT_JOBCLASS normal
setenv NC_VALID_DIRECTORIES ""
