Deprecated Commands
This section lists the recently deprecated and obsoleted Accelerator commands and options, and the corresponding current commands and options.
Deprecated Accelerator commands and options
Deprecated/Obsoleted Command or Option Current Command
lmresources Current command: lmhandlesall. For more information, refer to Match Jobs to Handles
-J Current command: -N. These options are used to set JobName. For more information, refer to Jobname Attribute. Also, see Node Fields for all the fields.
ccsub Current command: The option -clearcase in nc run. For more information, refer to Job Resources
