Configuration Management™ (CM) Guide
It is a recommended best practice to employ change control on your project configuration files.
- To impose strict change control on your project configuration files, and enable the ability to revert to a previous known good configuration.
- To quickly and efficiently model your production configuration in a test setup. Refer to Use CM in a Test Instance below.
- Set the NC_QUEUE variable:
setenv NC_QUEUE queue_name ncmgr cm <cm_command>
- Use either one of the -q or -queue options
to ncmgr.
ncmgr cm -q queue_name <cm_command>
- taskers.tcl
- policy.tcl
- equiv.tcl
- exclude.tcl
- resources.tcl
- security.tcl
- setup.tcl
ncmgr cm add<filename>
Functions Available
add
- Add a file to the repository and commit the change immediately. The repository must be previously initialized.
cat
- Show the displayable contents of a file.
commit
- Commit any outstanding file changes to the repository.
del
- Delete a file from the repository. The file in the working directory is unaffected.
diff
- Display any local changes that have been made to a file or files.
help
- Display help text.
init
- Initialize the CM repository for use with an Altair Accelerator project. This creates the repository (*.cmrepo) file in the NC_CONFIG_DIR directory (usually $VOVDIR/local/vncConfig/)
ls
- List project files that are currently under change control (use -v to also show file status).
open
- Open a repository and check out the files to the current working directory.
quickstart
- Initialize the repository and add the most common files (as listed in the previous section). This is typically done on a single queue to act as master.
revert
- Roll back any existing local changes to a file or files.
status
- Show the status of the local checkout set in the working directory.
timeline
- Show the timeline of changes to the repository.
undo
- Undo previous update or revert action.
update
- Update local file(s) with the latest from the repository, or a specific revision.
CM Command Usage
vncmgr: Usage Message
DESCRIPTION:
"ncmgr cm ..." is the utility for performing configuration management
actions. To use configuration management, you need to be in the
server-working directory (SWD) of the current project.
To work with a non-default queue name, either set the NC_QUEUE
environment variable to the target queue name or use either of the
"-queue" or "-q" arguments.
USAGE:
% ncmgr cm [-queue|-q QUEUE] <ACTION> [ARGUMENTS]
ACTIONS: (arguments are either <>=required or []=optional)
add <FILE> -- Add a file to the repository.
cat [-r REVISION] <FILE>
-- Display contents of a file.
commit <-m "MSG"> [FILE]
-- Commit changes to the repository.
del <FILE> -- Delete a file from the repository.
diff [-r REVISION] <FILE>
-- Display local changes.
help -- Display this help.
init -- Initialize repository.
ls [-v] <FILE>
-- List managed files.
Use -v to also show file status.
open -- Open a repository and check out files to the
quickstart -- Initialize repository and add most common files.
Typically done on a single queue to act as
master.
revert [FILE] -- Roll back local changes.
status -- Show status of the local checkout.
timeline [FILE] -- Show timeline of changes.
undo [FILE] -- Undo previous update or revert action.
update [-r REVISION] [FILE]
-- Update local file(s) with the latest from the
NOTE: For configuration management, you must be in the server working
directory (SWD) of the project being managed.
If you are unsure of this, please run the following commands:
% vovproject enable <project_name>
% cd `vovserverdir -p .`
EXAMPLES
% ncmgr cm quickstart
% ncmgr cm init
% ncmgr cm add policy.tcl
% ncmgr cm commit -m "Added new tasker." taskers.tcl
% ncmgr cm add scripts/myscript.tcl
% ncmgr cm commit -m "Added custom script to CM"
Implementing a configuration management process for your testing workflow can save a lot of time and hassle in keeping configuration files synchronized.
An example follows with a production instance called "vnc" and a test instance called "vnctest". For purposes of this example it is assumed that the repository has been previously set up, all desired config files have been added, and that two files have been modified and need to be synced to the test instance. The process consists of the following 2 steps:
