Accelerator and ClearCase: nc run -clearcase
To submit a job in a ClearCase view, use the option -clearcase with nc run.
% nc run -clearcase sleep 10
- The working directory of the job, which could be within the /vobtree, is likely to not exist on the tasker machine. For the directory to exist, the view must first be initialized. In this scenario, nc run -clearcase submits all jobs from the HOME directory of the user. The actual working directory of the job is stored in the VOV Properties VOVDIR attached to the job. The view name is stored in the property VIEW, also attached to the job.
- The command needs to be executed in the view context, which is normally done
with the following
command:
cleartool setview -exec "COMMAND" VIEWNAME
As COMMAND can be complex, it is best to wrap it into an auxiliary script. nc run -clearcase is used as a wrapper for the command vw ccexec. The utility ccexec is executed on the remote tasker and performs the following steps:- Gets the view name from the property VIEW attached to the job
- Gets the working directory of the job from the VOV Properties VOVDIR
- Creates a temporary script in /usr/tmp to change directory and execute the command
- Calls clearcase setview -exec ... VIEWNAME
