Simulation Settings
The simulation can be configured by specifying the area of planning, the resolution of prediction results, prediction height and whether additional prediction planes are defined in the database.
Click Edit Project Parameter dialog. The simulation settings are available on the Simulation tab.
to open theArea of Planning / Simulation
![](../../../../../images/winprop/user_guide/proman/propagation_projects/dailog_area_of_planning_rural.png)
![](../../../../../images/winprop/user_guide/proman/propagation_projects/dialog_area_of_planning.png)
![](../../../../../images/winprop/user_guide/proman/propagation_projects/dialog_area_of_planning_indoor.png)
Figure 1. The Area of Planning / Simulation group on the Edit Project Parameter dialog , Simulation tab.
- Prediction (simulation area)
- Individual for each transmitter
- The simulation area can be defined as a superposition of individual prediction areas defined separately for each transmitter/cell. These individual prediction areas can be defined on the Transmitter definition tab of the corresponding transmitter.
- Identical for all transmitters
- Rectangular area (Horizontal planes)
- The rectangular simulation area can be specified
by defining the lower-left and upper-right corner
coordinates. Another option is to use the
Prediction Rectangle (Rectangle) icon on the Project toolbar, which allows you to draw a rectangle with the mouse.
- Multiple Points (Arbitrary Heights)
Specify the individual prediction or receiver points. The points can be added, deleted, edited, imported or exported from or to a .txt file. The prediction points can be moved by specifying a translation vector.
Figure 2. The Prediction Point dialog.
Figure 3. The Prediction Point dialog.To move a prediction point with a moving object group, select the Time variant location (non-stationary) check box.
- Multiple Trajectories
Specify a prediction trajectory / receiver trajectory. A trajectory can be added, deleted, edited, imported or exported from or to a .txt file. For each trajectory, specify the name, x (Longitude), y (Latitude), z (Height), Velocity, Yaw1, Pitch2 and Roll3.
Figure 4. The Trajectory dialog.Another option to specify a trajectory is to use the
Prediction Trajectories icon on the Project toolbar, which allows you to specify the points for the trajectory using the mouse.
- Resolution of prediction results
- The resolution grid of the result matrix can be changed only if the database was not preprocessed in area mode.
- Prediction Height
The height of horizontal prediction planes can be defined relative to the ground level, absolute to sea level or relative to defined floor levels.
For prediction heights relative to ground, the height of interest is location-dependent. A typical example is where a person is walking in a hilly area with a cell phone.
For prediction heights absolute to sea level, the height of interest is fixed and does not follow the terrain. A typical example is where an aircraft flies at 1500 m.
For multi-floor buildings it is possible to define multiple heights for the coverage prediction (and also network planning). In case of a high number of floors it is not required to predict the coverage of every transmitter in each floor.
For example, a transmitter in ground floor has no influence on the coverage and interference in the highest floor. To speed up the simulation in case of multi floor buildings it is now possible to define a height range (for example, 3m), so that the coverage of a transmitter is only predicted for prediction heights within the defined range (difference between z-coordinate of transmitter and prediction height are within this range).
Tip: Specify multiple prediction heights by entering space-separated values.For example:
0.5 1.5 2.5
- Additional Prediction Planes
- When the Surface of Buildings check box is
selected, results will also be computed on surfaces of those buildings
for which Surface Prediction was defined in
WallMan. Those results will be visible
in the 3D view, not in the 2D view.
Figure 5. An example of predictions along building surfaces in an urban scenario.
- Trajectory sampling
The height of a prediction trajectory can be defined relative to the ground level or absolute to sea level.
For a prediction trajectory relative to ground, the height of interest is location-dependent. A typical example is where a person is walking in a hilly area with a cell phone.
ProMan also offers the possibility to do predictions on arbitrary user-defined prediction planes and on the surfaces of walls. Under Additional Prediction Planes, select the Prediction Planes defined in database check box and/or Surfaces of Walls check box.
Note: This options are only available, if the database of the current project supports this features (if this features are modeled / enabled in the database). Predictions on arbitrary predictions planes are possible using a ray-tracing model (SRT or IRT) or one of the empirical indoor wave propagation models.
Figure 6. An example of predictions along building surfaces in an indoor scenario.
The Simulation tab is related to radio network planning simulations and are therefore only available for network projects. Some of the general simulation parameters depend on the selected air interface.
