Antenna Settings
ProMan allows also the assignment of time-variant behavior to an antenna. The antenna moves in the same way as the group does to which the antenna was assigned.
The assignment of the antenna to a certain group can be done in the transmitter
dialog.
Note: Time-variant settings are available if the time-variant simulation is
enabled on the Edit Project Parameter dialog
(Simulation tab).
