Properties of Arms and Antennas
Arm1
  • Height (mounted): 9 m
  • Material: Steel
  • Length of both arms: 300 mm
  • Distance between both arms: 500 mm
  • Vertical tube:
    • Cross section: Rectangular
    • Length (Height): 1000 mm
    • Width (cross-section): 50 mm
  • Azimuth of arm: 180°
  • Antenna 1-1:
    • Azimuth: 0° (relative to arm)
    • Elevation: 0°
    • Phase offset: 0°
    • Radome
      • Type: Cuboid
      • Dimension: (W x D X H): 150 mm x 50 mm x 800 mm
      • Material: Steel
Arm 2
  • Material: Steel
  • Length of both arms: 450 mm
  • Vertical tube:
  • Azimuth of arm: 0°
  • Antenna 2-1:
    • Azimuth: 45° (relative to arm)
    • Elevation: 0°
    • Phase offset: 0°
    • Sub-arm:
      • Width: 40 mm
      • Distance between mounting points: 100 mm
      • Length: 50 mm
    • Radome
      • Type: Cuboid
      • Dimensions: (W x D x H): 150 mm x 50 mm x 800 mm
      • Material: Steel
  • Antenna 2-2:
    • Azimuth: 315° (relative to arm)
    • Elevation: 0°
    • Phase offset: 0°
    • Sub arm:
      • Width: 40 mm
      • Length of sub-arms: 50 mm
    • Radome
      • Type: Cuboid
      • Dimensions (W x D x H): 150 mm x 50 mm x 800 mm
      • Material: Steel
