Specifying the Output Folder for the Prediction Results
Specify the folder for the prediction results to be computed using the COST 231 - extended Walfisch-Ikegami model.
  1. Launch the Edit Project Parameters dialog using one of the following workflow:
    • On the Project menu, click Edit Project Parameters.
    • On the Project toolbar, click the Edit Project Parameters icon.
    • Press F3 to use the keyboard shortcut.
  2. Click the Propagation tab.
  3. Specify the output folder for the results to be computed using the dominant path model.
    1. Under Output Directory / Basic Filename for Propagation Results, in the Directory field, rename Prop02_DPM to Prop02_COST231.
Note: Keep the dialog open to define additional project parameters.
