Tutorial: Sketching, Surfacing, Modify
Create base sketches, from which you will create surfaces using the Extrude, Edge Extract, and Trim tools. You will then modify the surfaces further by adding sketch curves and using the Trim and Round tools.
- Create base sketches
- Then create surfaces using the Extrude, Edge Extract, and Trim tools
- Modify the surfaces further by adding sketch curves and using the Trim and Round tools
Create the Base Sketches
Sketch, Trim, and Round
Create a new Sketch #3 in the
Right view as shown.
- Exit the sketch.
- Add a Symmetry to the sketch using the Planar Symmetry tool.
Trim the surface with the Symmetry object.
Create the final Sketch #4 as shown.
Trim the surface with the sketch and remove the interior region.
Add a Round with a radius of 30
mm.
Add a second Round with radius of 5
mm, and box select the entire model.
