Result Types
A set of result types is available for each of the four analysis stages: injection, foaming, curing and defects.
Injection Results
Review material behavior through the injection stage. Result types for this stage include: Temperature, Head ID, Material ID, Density, Polyol [mg KOH], Pressure, Velocity, Mold Temperature, Isocyanate [wt%], and Viscosity.
Result Type Description
Temperature Review the temperature evolution of the material entering the part cavity. Check regions for excessive heating or cooling. Determine the appropriate fill speed for uniform temperature distribution.
Head ID Review injection results for material coming from a particular nozzle.
Material ID Review results for a particular material. Click the Show and Options buttons to change to velocity, contour-fill animation.
Density Consider material density through the progression of the injection stage.
Polyol [mg KOH] Review the levels of polyol that remain in the material.
Pressure Review the impact of pressure on the material during the injection stage.
Velocity Review the filling process, which is represented with vectors, to detect turbulences and velocities in the material.
Mold Temperature Review the temperature variance in the mold throughout the injection stage.
Isocyanate [wt%] Review the of isocyanate levels that remain in the polyurethane material.
Viscosity Review the dynamic viscosity of the polyurethane material.
Foaming Results
Review material behavior through the foaming stage. Result types for this stage include: Temperature, Head ID, Material ID, Density, Polyol [mg KOH], Pressure, Velocity, Isocyanate [wt%], and Viscosity.
Temperature Review the temperature evolution of the material during the foaming stage.
Head ID Review the foaming results for material coming from a particular nozzle.
Density Consider material density through the progression of the foaming stage.
Polyol [mg KOH] Review levels of polyol in the material.
Pressure
Review the impact of pressure on the material during the foaming stage.
Velocity
Review the foaming process, which is represented with vectors, to detect turbulences and velocities in the material.
Curing Results
Review material behavior through the curing stage. Result types for this stage include: Temperature, Head ID, Material ID, Density, Polyol [mg KOH], Pressure, Isocyanate [wt%], and Viscosity.
Temperature Review the temperature evolution of the material during the curing stage. Check regions for excessive heating or cooling.
Head ID Review curing results for the material coming from a particular nozzle.
Material ID Review the curing results for a particular material.
Density Consider material density during the curing stage.
Polyol [mgKOH] Review levels of polyol in the polyurethane material.
Pressure Review the impact of pressure on the material during the curing stage.
Defects Results
Review a range of defects that can occur at the end of the foaming process. Result types for this stage include: Air Pressure, Filling Time, Surface Defect Modulus, and Shrinkage Defect Modulus.
Option Description
Air Pressure Display the accumulated air pressure effects on the part at the end of the simulation. Look for porosity and void defects.
Filling Time
Review the time the material takes to reach different areas of the mold. Consider adjustments to the nozzle paths and tooling.
Option Description
Surface Defect Modulus Review the surface of the foam part for coarseness, toughness and melting that could be due to high mold temperatures, poor sealing, undried demolding spray, or contaminants. Consider controlling the mold temperature or modifying the sealing process. These surface defects can occur when a highly viscous foam flows through the mold.
The Surface Defect Modulus is dimensionless, and the result is displayed only on the surface between the part and mold. The following example, where (a) is 20℃, (b) is 40℃, and (c) is 60℃, shows a defect area that increases as the mold temperature increases.
Shrinkage Defect Modulus To produce results that predict the Shrinkage Defect Modulus, you must select Time as an ending condition when defining the Process Parameters for your analysis.
A shrinkage defect can occur if the polyurethane foam is too soft during the molding process or after demolding. Shrinkage can occur due to over-packing, slow gelling, and low index. Note that the shrinkage defect model is appropriate for flexible, polyurethane foam only, not rigid polyurethane foam.
The following examples show model results where (a) the mold is 40℃, (b) the mold is 20℃, (c) the temperature is shown through the cross-section of the part, and (d) the mold is 20℃ and the shrinkage modulus is shown.
No shrinkage occurs when the mold temperature is 40℃ (a). However, when the mold temperature dips to 20℃, shrinkage occurs as shown in (b). Looking at the cross-section (c), shrinkage occurs mainly on the outer surface of the part because the surface temperature is lower than the core temperature.
