Licensing
Licensing within the Panopticon Visualization Server supports the following license types:
q a volume-based XML file (named DatawatchLicense.xml) which is used to store all license information for a specific customer, must be copied to the designated AppData folder (i.e., c:\vizserverdata)
q Altair Units license which is available in the Altair License Server you are connected to (local or over the network)
The license file type you will use is delivered separately from the installation packages. Also, license files are required for both the Panopticon Designer (Desktop) and Panopticon Visualization Server components.
NOTE |
In the Panopticon product, these license types are still named HyperWorks Units and Hosted HyperWorks Units. For more information on Altair Units, visit https://www.altair.com/altair-units/.
