Features Added in Version 16.6.0
Data Connectivity
New Solace connector
New Order Book Reconstruction Transform
Ability to switch from Serpent to Pickle when connecting to Python
Support for time zone mapping in the RabbitMQ connector
Support for time zone mapping in the Kafka connector
Support for star schema in the JDBC Database connector
Support for GZIP and Deflate content encoding with HTTP header
Support for time zone fields and ability to parameterize them in the JSON, Text, and XML connectors
Support for spaces to be allowed for the generated column names in the JSON connector
New Ignore Empty cells option in the XMLA and XMLA On-demand connectors
Updated LiveView connectivity to minimize memory footprint
Updated LiveView connectivity to support reconnection after failure
New Save and Load column schema options in the AMPS connector
Support for longer SQL queries into the JDBC Database connector
Improvement in the ElasticSearch query performance
Visualization
New Shapes variable for Scatter Plot, Time Series Scatter Plot and Timeseries Combination visualizations
New Size variable for the Numeric Needle and Numeric Stacked Needle Graphs (to Display Tick Size)
Pivot Table/Heat Matrix visualization supports Totals & Sub Totals
Support for WebGL rendering for all Needle graphs
Dashboard
New Shape Legend
New JavaScript dashboard part
New Target Dashboard default value for the Parameter mode in Action controls
Support for the reset of visual filtering specific to each visualization
Leaf based Rank filtering to improve performance
Free Entry filter type in the Action Dropdown control and ability to type ahead to select from the matches
Support for QoD Calculated columns to be displayed when added to the Reference Line
Designer
Notification when deleting a data table that is referenced in Actions
Stop the reloading of data queries when changing calculations, display formats or display titles
Stop the reloading of data queries when changing parameters not impacting these queries
Stop the reloading of data query when opening Database data source
Stop the unnecessary reloading of data queries by improving Designer caching
Ability to set the BTF Cache In-memory Cache Limit
Server
Support for Tomcat 8.5
Support for OAuth 2.0 authentication
Expired Tokens are deleted on Server start up
New userSearchAsUser and roleSearchAsUser properties to enable the LDAP and Active Directory realms to use each user to extract their own details
Support to load workbook asynchronously during startup
Hide Login button through Server properties file
Add Dashboard name to data queries to support improved monitoring
Web Client
Support for the Numeric Stacked Needles visualization
Ability to disable the creation of multiple pages to show all data items when generating the PDF output
Improvement in the Single Selection Drop Down List filter summary text
Improvement in the Bookmarks panel styling
Support for On-demand loading in the Free Text Filter and Action Dropdown to minimize network bandwidth and server CPU
On-demand loading of Details to minimize network bandwidth and server CPU
Limit the resending of aggregate statistics to minimize network bandwidth and server CPU
Improvement in the serialization of time values statistics to minimize network bandwidth and server CPU
In addition, deprecation of the following:
Support for Tomcat 8.0
