Features Added in Version 16.5.0
Data Connectivity
New Kafka Publisher connector
New Input Validation for incorrect HTTP Header entries in the XML, JSON, Text, and HTML connectors
Support for query UI for the Data Extracts
Support for the retrieval of the history to the latest messages in the Apache Kafka connector
The ActivePivot Static Native connector is renamed XMLA
The ActivePivot QoD connector is renamed XMLA On-Demand
XMLA and XMLA On-Demand's performance significantly improved
Support for the Kafka Avro Publisher to enable looping of loaded CSV files and adding a timestamp field
Removal of the column order dependency when reading results in the Database connector
The AMPS connector supports the latest version (AMPS 5)
Support for the selection of a protocol in the AMPS connector
Support for the OrderBy and TopN functionality on AMPS subscriptions
Ability to generate columns in the AMPS connector to use the generic schema discovery framework and support JSON, XML, and FIX/NVFIX message types
Support for conflation in real time streaming connectors
Support for visualization of age in real time streaming connectors
Ability to set the required content-type header for the JSON, Text, and XML connectors
Visualization
New Funnel Chart visualization
New Waterfall Chart visualization
New Numeric Power axis
Ability to hide or display hidden columns in the Table visualization
Improved selection painting in the Table visualization
Ability to move columns in Table visualizations by dragging them to the left or right (except for Designer and embedded .NET client)
Designer
Ability to hide scroll bars in Filters, Action Drop Downs, and Legends when generating a PDF report
Ability to set Font settings in the Action Drop Down
Improved Unpivot
Ability to set background color for Panels
Ability to add more than one value for a column in the Static Filter
New Filter separator
Ability to reset filters in dashboards when parameters are updated
Server
User interface overhaul
Support for the change history of workbooks to be exposed and ability to republish older versions to the most recent one
Export PDF in parallel
Support for subscription limit
Web Client
Ability to copy Labels in visualizations
Labels in Bars in the Bar Graph are now being displayed
Support for background color in Panels
Support for Log10 scale
Support to view the set foreground and background colors of the Detail popup in visualizations
Support to view the set divider line between the visualization and its title
New style of dashboard tabs
Support for Adjust Column Width and Adjust All Column Widths in the Table visualization
Current parameter displayed in the Action Text Box
Support for Filter separator
Controls added in a Panel will automatically use the Panel's background color
In addition, deprecation of the following:
MDX-based connectors such as Analysis Services, MDX, and MDX Extended
