Overview: Working with Model Files
A Monarch Classic model file contains all of the definitions that you have created during a Monarch Classic session.
These include:
data extraction templates
external lookup parameters
field properties
filter definitions
sort and calculated field definitions
summary definitions
Models save work by allowing you to apply the same settings to a periodic report each time it is generated.
Notes:
To save more information that is not included in a model, such as which report file or which database you opened, as well as the model file, you should use a project file.
Several default settings are also saved in each model file. Settings saved in a model file take precedence over the defaults; when the model is loaded, the settings in the model override the defaults. For a list of all Monarch Classic definitions and settings and where each is saved, see Settings.
