Altair® Monarch®
Change Password Dialog
When configuring an export to a PDF file, use this dialog to specify the password that must be supplied to open the file or to change the permissions for it.
options
Field
Enter password
Enter the password you want to assign to the PDF  file.
Confirm
Confirm the password by entering it again.
Save password as PDF export default
Select if you want to use the specified password as the default password for all exported PDF files.
OK
Click to save changes you have made to the settings and close the dialog.
Cancel
Close the dialog without saving changes.
Help
Display this help topic.
