Line Selection Area
A vertical area (shown below enclosed in a red box) at the left edge of the Report window:
The line selection area displays an indicator (>>) next to each line currently trapped by a Monarch Classic template. Clicking on the line selection area and dragging your mouse downwards allows you to select entire lines in a report.
The line selection area is also indicated when a bookmark has been defined for that line.
