Altair® Monarch®
Report Design Basics
Monarch Data Prep Studio is not limited to working with databases and tables. You can also open a PDF/PRN report and select the fields that you want to include in a table. Once the table has been completely defined, it is included in the Preview Window from where you can load and combine it with other available tables.
  1. Open your PDF/PRN document.
    You can:
    You are brought to the Report Design Window:
  2. Define templates to extract the data from your document:
    When your trapping operations are completed, Monarch Data Prep Studio will create a new column for each field that you define and populate that column with similar field values:
  3. Select Accept to complete Report Design. The table you just defined is included in the Preview Window as a Monarch report node.
    You can load multiple reports into this node by clicking on the drop-down button located to the right of the parent table and then selecting Report Options > Add Report.
    Note, however, that added reports must have the same format and be of the same file type to enable correct data capture.
Related Links
