Altair® Monarch®
Redacting Field Values
Monarch Data Prep Studio's redaction feature allows you to replace, or mask out field values, so that only a representation of the field value is displayed, and not the actual value.
For instance, you can redact Credit Card Numbers to look like this:
Actual Credit Card Number Value
Redacted Credit Card Number Value
1345-8716-4432-7892
xxxx-xxxx-xxxx-7892
3455-6457-3354-8875
xxxx-xxxx-xxxx-8875
0981-3245-1234-4456
xxxx-xxxx-xxxx-4456
This functionality is very useful for users who wish to share reports but need to hide actual data values, for example:
  • Analysts who wish to publish the results of their analysis of business data but must obscure any sensitive values.
  • Users experiencing problems with their reports or models who want to "sanitize” their reports via redaction before sending them to Altair Support for detailed analysis.
Monarch Data Prep Studio provides several redaction methods and you can select the best one to suit your requirements:
Method Name
Sample Actual Value(s)
Redacted Value
X-over text
All characters are replaced with x.
Note  You can only apply this method to columns with Text data type. Use a convert operation to convert your column values to text.
"Fred R. Persky   "
[xxxxxxxxxxxxxxxxx]
X-over digits
All numeric characters are replaced by x.
Note  You can only apply this method to columns of type text. Use a convert operation to convert your column values to text.
903-45-7654
xxx-xx-xxxx
X-over digits except last 4
All numeric characters except the last 4 are replaced by x.
903-45-7654
xxx-xx-7654
X-over non-blanks
All characters except blanks are replaced with x.
"Fred R. Persky   "
“xxxx xx xxxxxx   ”
Replace with blanks
All characters are replaced with blanks.
“Fred R. Persky   ”
  1. In the Prepare Window, right-click on one or multiple column headers to display the corresponding context menu.
  2. Select Redact.... The Redact dialog displays:
  1. Select the RedactionType from the drop-down list.
  2. Select OK.
