Monarch 2020 Features
The list below highlights new features in the Monarch version indicated.
Monarch 2020.1
Monarch Classic Highlights:
Localization for French and German
Monarch Utility – Redact sample lines from Models and Workspaces
Monarch Utility – Clear credentials from Workspaces, Projects, and Models
YearFrac Function
Various bug fixes
Various UI/UX improvements
Data Prep Studio Highlights:
YearFrac function
Various bug fixes
Various UX/UI improvements
Monarch 2020.0
Support for passwords of any length
Support for password-protected Excel inputs
Support for Excel XLSB inputs
Support for scientific notation in the Expression Editor
Monarch Utility: Ability to perform XMOD to DMOD conversion via the command line
PDF input engine enhancements, including Snap Left and Snap Up to improve alignment for certain files
Various bug fixes
Ability to specify column types in load options for delimited text
Editing of cleared credentials for tables saved in workspaces
Fixing of problematic transforms and appends
Support for passwords measuring a maximum length of 128 characters
Worksheet Design - "Excel Trapping" for extracting data from complex, hierarchical Excel Worksheets
Export/import tables to/from workspaces
New functions: Remove Alpha Characters, Insert Text, Max Split Count for Left/Right Split
Support for password-protected Excel (.xlsx) file imports via Worksheet Design and the native Monarch Excel Table connector
Support for hosted HyperWorks Units and HyperworksEDU
Enhanced column list
Save workspaces without file data
New Map Columns dialog to try and accommodate schema changes in underlying data sources
New metadata column for worksheet names from Excel files
Enhanced security options for passwords and other sensitive connection string parameters
Dynamic sheet name/location support
Various UX improvements
NOTES:
If you have a license for Monarch Complete, you will have access to both Classic and Data Prep Studio features.
If you have a license for Monarch Classic, you will have access to Classic features only.
Contact Altair Sales if you would like to upgrade your license to gain access to all of the features listed above and more.
Related links
