Work Folder
A folder where Monarch Classic stores temporary files. Work folders can be defined in Advanced Options. The default folders, established when Monarch Classic first runs after installation, default to the user Temp folder, reflected by the %TEMP% environment variable.
However, you may specify different work folders. Refer to Settings for more information.
