Altair® Monarch®
Column Function
Returns the column (within a Multi-Column Region) on the report page of the last detail line for a record. Note: The value is always 1 if the Multi-Column Region is not active.
Column()
Arguments
None.
Return value
This function returns a number.
Calculated field example
If a report contains three columns and the detail name WEELKES, T. appears on the third column, the following calculated field expression for this detail would return the number 3: Column()
