Column List
Allows you to:
Edit column information:
Rename a column
Change the field type (text, date/time, numeric)
Set the format for date/time or numeric fields
Reposition (rearrange) columns within a table
Hide/unhide individual or all columns
Set name casing (proper case, upper case, lower case)
Apply selected format to all other fields of the same type (for numeric and date/time fields)
View the number of columns included in the table and the macros applied to them
RELATED linkS
