Adding Exports
You can easily add an export to your project from within Export Design.
Creating new exports
Go to Export Design.
Select Add Export on the Export Design ribbon. The Add Export dialog displays.
Select a source from the Source View selector.
Specify the Export File Type on the Export File Type panel.
Select Add. The export definition is added to the project and it's properties are displayed on the Export Design Window.
If you wish to run your newly-created export, refer to Running Exports.
