Push, pull, scale, rotate, or project a face to modify the geometry of a
PolyNURBS.
Click Edit, or double-click a PolyNURBS object to enter
editing mode.
Choose from the following options:
To
Do this
Note
Push/pull a face (a precise distance)
Drag the face.
To push/pull the face a precise distance, enter a distance
in the microdialog.
Push/pull a selected face
When you select a face, an arrow appears at the center of
the face.
Drag the arrow at the center to push/pull the
face.
Hold down Ctrl while dragging to
create a new cage face.
Scale a selected face
When you select a face, planes appear at the corners of
the face.
Drag a plane at the corner to scale the face.
to scale the face about its center.
Hold down Ctrl+Shift while
dragging to scale the face about its center while
maintaining the original aspect ratio.
Rotate a selected face about its center
When you select a face, a curved arrow appears when you
hover over a corner or an edge. Figure 1. Hover over a cornerFigure 2. Hover over an edge
Drag the curved arrow to rotate the face about its
center.
Move an edge along the plane of a selected face
When you select a face, a straight arrow appears when you
hover over an edge.
Drag the straight arrow to move the edge along the
plane of the face.
lengthen or shorten the original face symmetrically.
