Create Materials
Customize a material and add it to My Materials.
Use the Designate Part Cavity or the Auto
Configure Components tool to indentify the part cavity.
- Select the View Materials icon in the microdialog.
Click Edit on the Materials dialog.
The editing operation moves you into the My Materials tab.
- Edit Thermal, Rhealogical, Mechanical, PVT or Fiber properties.
Enter a New Material Name at the bottom of the dialog
and click Save.
The customized material is saved and accessible from the My Materials tab for future use.
- Click the Select button to assign the new material to your model.
