Torques
A torque is a twisting force. It is a type of load and can be applied either to a face or the center of a hole, in which case it acts on the interior face of the hole. Use the Apply Torque tool on the Loads icon to apply a torque.
Torques are represented as curved arrows and always act around an axis of rotation, which is drawn as a centerline as shown below.
Figure 1. Torques Applied to a Hole Center and a Surface
Apply a Torque
Select the Torque tool, click on a face or hole, and enter a magnitude.
- A torque represents a twisting force across the entire face, centered around the point where it is applied.
- When created, torques are automatically assigned to the current load case.
- Use the Property Editor to change the name, magnitude, mode, direction, and appearance of the torque.
Microdialog Options
Double-click a torque arrow to enter editing mode, which opens the Torque microdialog.
Change the direction of the torque. |
Enter a magnitude for the torque. The magnitude of a torque is equal to force multiplied by distance. |
Click the icon to switch between direction torque mode and component torque mode. |
Click the icon to enter/exit Multi-Selection mode. In this mode, you can click a feature to add/remove it from the selection. Outside of this mode, you need to hold down Ctrl while clicking. |
Translate or rotate the torque using the Move tool. Use to place a torque at a distance. |
Align the torque to the x, y, or z axis. |
Align the torque normal (perpendicular) to the face. |
Align the torque to the centerline of a hole. (This button only appears if the torque is applied to the center of a cylindrical hole.) |
Click the chevron to orient the torque by entering either vector torques (X, Y, and Z) or component torques (Tx, Ty, Tz). |
Mouse Controls and Keyboard Shortcuts
Ctrl | Apply the torque to multiple features on the same part. |
Shift | Apply the torque to a point on the interior of a hole. |
Right-click and mouse through the check mark to exit, or double-right-click. | Exit the tool. |
