Altair Inspire checks for potential problems with the model before running an analysis or optimization and will suggest
solutions when problems are found.
There are a number of problems that can prevent analysis or optimization from running successfully. The most common
reasons for failed runs are improperly defined load cases.
There is a syntax error in the solver expression entered for the
Profile Function in a motor or actuator. Open the Property Editor to
review the expression for errors.
