Altair Inspire checks for potential problems with the model before running an analysis or optimization and will suggest
solutions when problems are found.
There are a number of problems that can prevent analysis or optimization from running successfully. The most common
reasons for failed runs are improperly defined load cases.
Note: Check the run.log file located in the File > Preferences > Inspire > Analysis > Run History Path. (The support team will want to review this
file.)
