Model ElementThe
UserMsg element allows you to control the output of MotionSolve messages.
Any message that MotionSolve prints to standard output goes through the
Attribute Summary
Name |
Property |
Modifiable by command? |
Designable? |
function |
Function |
NO |
NO |
routine |
Routine () |
Usage
# Defined in a Python function
UserMsg_0 = UserMsg (routine=onError)
Attributes
User-subroutine defined in a compiled DLL
- function
- String defining a valid user function.
- The list of parameters that are passed from the data file to the user
defined subroutine where the UserMsg is defined.
- The function attribute is optional.
- routine
- String
- Specifies an alternative name for the user subroutine. The name consists
of two pieces of information, separated by “∷”. The first is the
pathname to the shared library containing the. The second is the name of
the function in the shared library.
- An example is: routine=”/staff/Altair/engine.dll∷myMsgSub”
- ”/staff/Altair/engine.dll
is the DLL
- “myMsgSub” is the function within
this DLL that is invoked by MotionSolve when
writing messages
- The attribute routine is optional.
- When not specified, routine defaults to
“MSGSUB”.
User-subroutine defined in a user-written Python script
- function
defined subroutine.
- routine
- Pointer to a callable function in Python.
- An example is: routine=myMsgSub.
- myMsgSub is a
Python function or method that can be called from wherever the
model resides.
MSGSUB.
Examples
Define a user_message to write to a
file.
UserGraphic (function="USER(0)", routine=myMsgSub)
def myMsgSub (msgid, time, par, npar, msgtype, iflag, endflag, message, outname):
# implementation goes here...
return 0
- See Properties for an explanation about what properties are, why they
are used, and how you can extend these.
