Triamesh
Model ElementThe Triamesh element allows you to represent a geometric figure using a series of nodes and faces.
Class Name
Triamesh
Attribute Summary
Name Property Modifiable by command? Designable?
rm Reference (Marker) NO NO
nodes Double (count=0)
faces Int (count=0)
refinement_level Int ()
material_inside Bool ()
color String()
Usage
nodes = [[0,0,0],[1,1,1],[-1,1,1]]
faces = [[0,1,2]]
Triamesh(rm=rm,nodes=nodes,faces=faces)
Attributes
rm
Reference(Marker)
The marker is used as a coordinate system for the triamesh graphic.
nodes
Int()
The list of nodes that define the Triamesh.
faces
Int()
List of faces that define the Triamesh.
refinement_level
Int()
Specifies the level of detail of the sphere entity. Default is 10.
coils
Int()
Specifies the number of coils to represent the Spring graphic.
material_inside
Bool()
Specifies if the graphic has material inside or outside. material_inside is a boolean flag (TRUE/FALSE).
TRUE means the geometry is solid. In other words, it is filled with material and its exterior is devoid of material. Consequently, the surface normals of the geometry point outward.
FALSE means the converse: The exterior of the geometry is filled with material and the interior is devoid of material. In this case, the surface normals of the geometry point inward.
color
String()
The color of the graphic for H3D animation. Specified as RGB (Red : Green : Blue).
  1. See Properties for an explanation about what properties are, why they are used, and how you can extend these.
