Supported Solver Subroutines
To write a user subroutine, you first have to determine which user subroutine you need to use and select a programming language.
Listed below are supported solver subroutines and the corresponding user defined entity.
Subroutine Name
Corresponding MotionSolve XML Element
ARYSUB
<Reference_Array>
CNFSUB
<Force_Contact> - Normal force only
CFFSUB
<Force_Contact> - Friction force only
CONSUB
<UserProgramControl>
CONTACTPOST
<Force_Contact> - Custom processing of contact results
COUSUB/COUXX/COUXX2
<Constraint_Coupler>
CURSUB
<Reference_ParamCurve>
DIFSUB
<Control_Diff>
DMPSUB
<Body_Flexible>
FIESUB
<Force_Field>
GCOSUB
<Constraint_General>
GFOSUB
<Force_Vector_OneBody|TwoBody> - when type is ForceAndTorque
GRASUB
<Post_Graphic>
GSESUB/GSEXX/GSEXU/GSEYU/GSEYX
<Control_StateEqn>
MARKER_READ
<Reference_Marker>
MATRIX_READ
<Reference_Matrix>
MESSAGE_SUB
<Messaging>
MFOSUB
<Force_FlexModal>
MOTSUB
<Motion_Joint|Marker>
NFOSUB
<Force_MultiPoint>
PFOSUB
<Force_Penalty>
PINSUB
<Control_PlantOutput>
POST_SUB
<Post_UserAPI>
POUTSUB
PTDSFSUB
<Force_PTdSF>
RELSUB
<Load_Model>
REQSUB
<Post_Request>
SAVSUB
<Save>
SENSUB
<Sensor_Event>
SEVSUB
<Sensor_Evaluate>
SFOSUB
<Force_Scalar_TwoBody>
SPLINE_READ
<Reference_Spline>
STRING_READ
<Reference_String>
SURSUB
<Reference_ParamSurface>
TUNSUB
<Param_Simulation>
UCOSUB
<Constraint_UserConstr>
VARSUB
<Reference_Variable>
VFOSUB
<Force_Vector_OneBody|TwoBody> - when type is ForceOnly
VTOSUB
<Force_Vector_OneBody|TwoBody> - when type is TorqueOnly
YFOSUB/YFOXU/YFOXX/YFOYU/YFOYX
<Force_StateEqn>
To help you create a user subroutine, included in the installation is a series of simple routine templates (one for each supported routine) in Fortran, C/C++, Python and Compose/MATLAB programming/scripting languages. These templates are located in the following installation directories:
<install-path>\hwsolvers\motionsolve\usersub\f_src
<install-path>\hwsolvers\motionsolve\usersub\c_src
<install-path>\hwsolvers\motionsolve\usersub\mex
<install-path>\hwsolvers\motionsolve\usersub\py_src
Also included in the installation directory is a Microsoft Visual Studio Project file that can be optionally used to create your user library (DLL, Dynamic-Link Library).
The C/C++ simple routine templates included in the installation contain the required include statements:
  • msolvsub_c_include.h for C/C++ code.
This external file is used to resolve the symbols of the various utility functions that can be invoked. They contain the function prototypes of utility functions like SYSFNC, AKISPL, and all other utility functions that can be used to access system states (displacement, velocity, acceleration, forces, and so on) and MotionSolve states (current simulation time, solver mode, and so on).
You can simplify the process of creating the DLL by using Microsoft Visual Studio with the supplied project file which contains all compiler and linker options, the name of the generated DLL, and the pointers to all source files used for generating the DLL.
