RequestResult
Results ElementRequestResult is an object that contains all the simulation results associated with a single Request.
Class Name
RequestResult
At each output time, the following results are stored:
Entity Component Name
Displacement Request MAG, X, Y, Z, PSI, THETA, PHI
Velocity Request VM, VX, VY, VZ, WM, WX, WY, WZ
Acceleration Request ACCM, ACCX, ACCY, ACCZ, WDTM, WDTX, WDTY, WDTZ
Force Request FM, FX, FY, FZ, TM, TX, TY, TZ
User Request F1, F2, F3, F4, F5, F6, F7, F8
The following occurs automatically when the model.simulate() method is invoked with returnResults=True
  • At T=0, for each Request in the model
    • A RequestResult object is created.
    • The object is stored in the SimulationResults container object.
  • At each output time (including T=0):
    • for each Request in the model:
      • The Request results are appended to the RequestResult object.
  • Thus, at the end of the simulation, the SimulationResults object is fully "populated".
Usage
See SimulationResults
Demonstrate the use of RequestResult to create plots from MotionSolve results.
Assume a model, M, is given to you.
  • Perform a dynamic simulation from 0 to 2 seconds with 200 output steps.
  • Extract the time history for the FZ component of force request forceRequest1.
  • Plot the FZ time history in matplotlib.
# Perform a simulation
run = M.simulate(type="DYNAMICS", end=2, steps=200, returnResults=True)
# Get the force request data from the run object
req = run.getObject (model.forceRequest1)
# Extract the time and FZ signals
times = req.getComponent ("times")
FZ = req.getComponent ("FZ")
# Plot the signal
import matplotlib.pyplot as plt
plt.plot (times, FZ)
plt.title ("Fz vs. Time")
plt.xlabel ("Time")
plt.ylabel ("force [N]")
plt.grid (True) plt.show ()
  1. See Properties for an explanation about what properties are, why they are used, and how you can extend these.
  2. The SimulationResults may be queried to get access to the time histories of its various components.
