createModel Method
Creates a model object.
The model is a container object. All the modeling entities are stored in this container object. The model object is provided to the optimizer to do the optimization.
The createModel method for the FourBar class relies on two helper functions, make_cylinder to create cylinders and make_joint to create joints. These simplify modeling.
def createModel (self):
  def make_cylinder (a, b, r, rho, label):
    r2      = r*r
    h2      = (a[0]-b[0])**2 + (a[1]-b[1])**2 +
              (a[2]-b[2])**2
    h       = math.sqrt(h2)
    mass    = math.pi * r2 * h * rho
    ixx     = iyy = mass * (3 * r2 + h2) / 12
    izz     = mass * r2 / 2
    qploc   = (a+b)/2
    xploc   = qploc + [0,0,1]
    cyl     = Part (mass=mass,
              ip=[ixx, iyy, izz],
              label=label)
    cyl.cm  = Marker (body=cyl, qp=qploc, zp=b
              xp=xploc, label=label + " CM")
    cyl.gcm = Marker (body=cyl, qp=a, zp=b,
              xp=xploc, label=label + "_Cyl CM")
    cyl.gra = Graphics (type="CYLINDER",
              cm=cyl.gcm, radius=r, length=h,
              seg=40, label=label + " Cylinder")
    cyl.req = Request (type="DISPLACEMENT",
              i=cyl.cm,
              comment=label + " CM displacement",
              label=label + " CM displacement")
    return cyl
  def make_joint (p2, p1, loc, loc2, jtype, pt):
    if jtype == "UNIVERSAL":
      ux     = Vector(1,0,0)  # Global X
      uz     = Vector(0,0,1)  # Global Z
      xiloc  = loc + ux       # Xi along global X
      ziloc  = loc + uz       # Zi along global Z
      xjloc  = loc + uz       # Xj along global Z
      ubc    = (loc-loc2).normalize()
      zixbc  = uz.cross (ubc).normalize ()
      zjloc  = pc+zixbc
      mi     = Marker (body=p2, qp=loc, zp=ziloc,
               xp=xiloc, label="UNIV@ C I")
      mj     = Marker (body=p1, qp=loc, zp=zjloc,
               xp=xjloc, label="UNIVL@ C J")
    else:
      xploc = loc + [1,0,0]
      zploc = loc + [0,0,1]
      mi    = Marker (body=p2, qp=loc, zp=zploc,
             xp=xploc, label=jtype+"@"+pt+" I")
      mj    = Marker (body=p1, qp=loc, zp=zploc,
              xp=xploc, label=jtype+"@"+pt+" J")
    joint = Joint (type=jtype,  i=mi, j=mj,
            label=jtype+"@"+pt)
    return joint
  m      = Model (output="test-4bar")
  units  = Units (mass="KILOGRAM",
           length="MILLIMETER",
           time="SECOND",
           force="NEWTON")
  grav   = Accgrav (jgrav=-9800)
  H3dOutput (grasave=True)
  # define the design variables
  m.ax = ax = Dv (label="XA", b=self.ax,
              blimit=self.ax_lim)
  m.ay = ay = Dv (label="YA", b=self.ay,
              blimit=self.ay_lim)
  m.bx = bx = Dv (label="XB", b=self.bx,
              blimit=self.bx_lim)
  m.by = by = Dv (label="YB", b=self.by,
              blimit=self.by_lim)
  m.cx = cx = Dv (label="XC", b=self.cx,
              blimit=self.cx_lim)
  m.cy = cy = Dv (label="YC", b=self.cy,
              blimit=self.cy_lim)
  m.dx = dx = Dv (label="XD", b=self.dx,
              blimit=self.dx_lim)
  m.dy = dy = Dv (label="YD", b=self.dy,
              blimit=self.dy_lim)
  rad, rho = 10, 7.8e-6
  pa = Point(ax,ay,0)
  pb = Point(bx,by,0)
  pc = Point(cx,cy,0)
  pd = Point(dx,dy,0)
  #Ground
  p1     = Part   (ground=True)
  oxyz   = Marker (body=p1, label="Global CS")
  #crank, coupler, follower parts
  m.crank    = p2 = make_cylinder (pa, pb, rad,
                    rho, "Crank")
  m.coupler  = p3 = make_cylinder (pb, pc, rad,
                    rho, "Coupler")
  m.follower = p4 = make_cylinder (pc, pd, rad,
                    rho, "Follower")
  m.coupler.azMarker = Marker (part=p3,
                       qp=p3.cm.qp)
  #Joints + motion @A to drive system
  ja      = make_joint (p2, p1, pa, None,
            "REVOLUTE",  "A")
  jb      = make_joint (p3, p2, pb, None,
            "SPHERICAL", "B")
  jc      = make_joint (p4, p3, pc, pb  ,
            "UNIVERSAL", "C")
  jd      = make_joint (p1, p4, pd, None,
            "REVOLUTE",  "D")
  m.j1mot = Motion (joint=ja, jtype="ROTATION",
            dtype="DISPLACEMENT",
            function="360d*time")
  self.mbsModel = m
  return m
