Application Area 6: Optimize Dynamic Response
Often the task of optimization is to find the values of some design variables so that the dynamic response is optimized in some way.
The figure above shows a simple representation of a stabilizer. The stabilizer is basically a PID controller that prevent the mass from deviating from its initial point. The disturbing force is a time variant function.
Objective
Minimize the integral of displacement magnitude, velocity magnitude and acceleration magnitude over time. Keep the value of gains under a certain number. (This is done by adding constraints).
Design Variables
Three gains of PID controller k p , k d , k i MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaebbnrfifHhDYfgasaacH8srps0l bbf9q8WrFfeuY=Hhbbf9v8qiqrFr0xc9pk0xbba9q8WqFfea0=yr0R Yxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeGabeqadiWa ceGabeqabeqadeqadmaakeaaieGaqaaaaaaaaaWdbiaa=TgapaWaaS baaSqaa8qacaWFWbaapaqabaGcpeGaaiilaiaa=bkacaWFRbWdamaa BaaaleaapeGaa8hzaaWdaeqaaOWdbiaacYcacaWFGcGaa83Aa8aada WgaaWcbaWdbiaa=Lgaa8aabeaaaaa@3C8D@ .
Note: For this example, finite differencing is used to compute the sensitivities. The code with detailed explanation is provided in the PID Controller Example section.
