Mate
Model ElementMate is used to specify general mating constraints between geometric primitives. Mate differs from JOINT and JPRIM in that it specifies more general constraints based on distance, tangency, and coincidence relations between mating geometries.
Class Name
Mate
Attribute Summary
Name Property Modifiable by command? Designable?
id Int ()
label Str () Yes
type Enum (Type)
i Reference ("Marker") Yes Yes
j Reference ("Marker") Yes Yes
radius Double () Yes FD Only
iradius Double () Yes FD Only
jradius Double () Yes FD Only
dist Double () Yes FD Only
height Double () Yes FD Only
active Bool () Yes
virtual Bool () Yes
*Type ("COI_POI_CYL",   "COI_POI_SPH",   "COI_POI_LIN",   "COI_POI_POI",
       "COI_POI_CON",   "COI_LIN_LIN",   "COI_LIN_CYL",   "COI_LIN_PLA",
       "DIS_POI_POI",   "DIS_POI_SPH",   "DIS_POI_LIN",   "DIS_POI_CYL",
       "DIS_SPH_SPH",   "DIS_SPH_LIN",   "DIS_SPH_CYL",   "DIS_SPH_CON",
       "DIS_SPH_PLA",   "DIS_LIN_LIN",   "DIS_LIN_CYL",   "DIS_LIN_PLA",
       "DIS_CYL_CYL",   "DIS_PLA_CON",   "DIS_PLA_CYL",   "TAN_SPH_LIN",
       "TAN_SPH_CYL",   "TAN_SPH_PLA",   "TAN_SPH_CON",   "TAN_SPH_SPH",
       "TAN_LIN_CYL",   "TAN_CYL_CYL",   "TAN_PLA_CYL",   "TAN_PLA_CON")
Usage
Mate (i=objMarker, j=objMarker, type=string, optional_attributes)
Attributes
i
Reference to an existing marker
Specifies a marker that defines the connection on the first part. The part may be a rigid, a flexible, or a point mass.
This parameter is mandatory.
j
Specifies a marker that defines the connection on the second part. The part may be a rigid, a flexible, or a point mass.
type
Specifies the type of mate between I and J.
The table below shows the different types of MATES and the number of degrees of freedom removed.
Mate Type # Mate Type # Mate Type #
COI_POI_SPH
DIS_POI_POI
DIS_POI_SPH
DIS_SPH_SPH
TAN_SPH_SPH
COI_POI_CYL
DIS_POI_LIN
DIS_POI_CYL
DIS_SPH_LIN
DIS_SPH_CYL
TAN_SPH_LIN
1
1
1
1
1
1
1
1
1
1
1
TAN_SPH_CYL
COI_LIN_CYL
DIS_LIN_LIN
DIS_LIN_CYL
DIS_CYL_CYL
TAN_LIN_CYL
TAN_CYL_CYL
COI_LIN_PLA
COI_POI_POI
COI_POI_LIN
COI_LIN_LIN
1
3
2
2
2
2
2
2
3
2
4
DIS_LIN_PLA
DIS_PLA_CYL
TAN_PLA_CYL
DIS_SPH_PLA
TAN_SPH_PLA
COI_POI_CON
DIS_SPH_CON
TAN_SPH_CON
DIS_PLA_CON
TAN_PLA_CON
2
2
2
1
1
1
1
1
3
3
id
Integer
Specifies the element identification number. This number must be unique among all the MATE objects in the model.
This attribute is optional. MotionSolve will automatically create an ID when one is not specified.
Range of values: id
label
String
Specifies the name of the MATE object.
This attribute is optional. When not specified, MotionSolve will create a label for you.
radius
Double
Radius of the circle/sphere specified in the mate constraint.
This attribute is mandatory for some MATEs, and unnecessary for others. 1
iradius
Double
Radius of the I part circle/sphere specified in the mate constraint.
jradius
Double
Radius of the J part circle/sphere specified in the mate constraint.
dist
Double
Distance between the two parts constrained by the DIS.
height
Double
Height of the part specified in the mate constraint.
active
Boolean
Select one from "TRUE" or "FALSE"
  • "TRUE" indicates that the element is active in the model and it affects the behavior of the system
  • "FALSE" indicates that the element is inactive in the model and it does not affect the behavior of the system. It is almost as if the entity was removed from the model, of course with the exception that can be turned "ON" when desirable.
The attribute active is optional. When not specified, active defaults to "TRUE"
virtual
Boolean
Defines whether the constraint is virtual or regular. Select "TRUE" or "FALSE".
  • TRUE” indicates that the constraint is implemented as a virtual constraint.
  • FALSE” indicates that the constraint is implemented as a regular algebraic constraint.
Optional. When not specified, virtual defaults to “FALSE”. For a more detailed explanation about virtual, see Constraint: Joint.
Examples
Create a MATE of type TAN_PLA_CON.
TanPlaCon = Mate (label="Mate1", i=imark, j=jmark, type="TAN_PLA_CON", radius=600, height=800)
Create a MATE of type TAN_PLA_CYL. Then set its radius to 0.035.
TanPlaCyl = Mate (label="Mate2", i=imark, j=jmark, type="TAN_PLA_CYL")
TanPlaCyl.radius=0.035
  1. The table below shows the attributes accepted by each type of mate.
  2. See Properties for an explanation about what properties are, why they are used, and how you can extend these.
  3. For a more detailed explanation about Mate, see Constraint: Mate.
  4. For a more detailed explanation about virtual, see Constraint: Joint.
