GET_MATRIX_INFO
Utility/Data Access SubroutineReturns information about a Reference_Matrix element.
Use
The function can be called by any user subroutine.
Fortran Calling Syntax
CALL GET_MATRIX_INFO(id, type, nrows, ncols, size, ierr)
C/C++ Calling Syntax
c_get_matrix_info(id, type, nrows, ncols, size, ierr)
Python Calling Syntax
[type, nrows, ncols, size, ierr] = py_get_matrix_info(id)
MATLAB Calling Syntax
[type, nrows, ncols, size, ierr] = m_get_matrix_info(id)
Attributes
id
[integer]
The ID of the Reference_Matrix element.
Output
type
[integer]
The type of Reference_Matrix as follows:
1
Sparse.
2
Full, row-order.
3
Full, column-order.
nrows
[integer]
The number of rows.
ncols
[integer]
The number of columns.
size
[integer]
The total number of entries. For sparse matrix, it is the number of non-zero entries. For full matrix, it is nrows*ncols.
ierr
[integer]
An integer that specifies the status of the call to the GET_MATRIX_INFO as follows:
0
Normal return.
1
ID not found, call ignored.
