createSteelBar
Modeling FunctionCreates a bar between two given points.
With createSteelBar, you can specify the radius and the density of the bar, which will be used to compute the mass and intertial properties. A rigid body, its cm marker, and a cylinder (graphics) are created and the body created is returned.
Usage
bar = createSteelBar (ipoint, jpoint, radius=None, density=7.8e-6, **kwds)
Input Arguments
ipoint
The starting point of the bar.
jpoint
The end point of the bar.
radius
The radius of the bar.
density
The density of the bar.
kwds
Other properties that define the graphic entities, for example, color.
Return Value
bar
The rigid body created.
Usage
# Create a bar between (0,0,0) and (1,1,1)
ipoint = Point(0,0,0)
jpoint = Point(1,1,1)
radius = 0.1
density = 1e6
bar = createSteelBar(
     ipoint = ipoint,
     jpoint = jpoint,
     radius = radius,
     density = density
