createRevoluteJoint
Modeling FunctionDefines a revolute joint between two bodies.
Defintion
createRevoluteJoint creates the I and J marker and returns the joint object created. All properties of a revolute joint are supported by keyword arguments.
Signature
joint = createUJoint(ibody, jbody, location, ishaft, jshaft, **kwds)
Input Arguments
ibody
The first body on which the joint is created.
jbody
The second body on which the joint is created.
location
The location where the joint is created.
ishaft
The direction of ishaft if a Vector is given, otherwise it defines the end point.
jshaft
kwds
Keyword arguments that define other properties of the joint.
Return Value
joint
The revolute joint created.
Usage
# Create a revolute Joint at (1,1,1) and the zaxis is (0,0,1)
part1 = Part(mass=1, ip=[10,10,10], cm=Marker())
part2 = Part(mass=1, ip=[10,10,10], cm=Marker())
joint = createRevoluteJoint(
     ibody = part1,
     jbody = part2,
     location = Point(1,1,1),
     axis = Point(1,1,2),
     ic = [0.0, 0.0]
