HM-3000: Create 1D Elements
In this tutorial you will learn how to build 1D elements.
This exercise uses the 1d_elements.hm file, which can be found in the hm.zip file. Copy the file from this directory to your working directory.
Open the Model File
In this step you will open the model file, 1d_elements.hm.
- Start HyperMesh Desktop.
- From the menu bar, click .
- In the Open Model dialog, open the 1d_elements.hm model file.
Create 1D Bar Elements
In this step you will create 1D bar elements.
Create 1D Elements Along a Line
In this step you will create 1D elements along a line.
Create 1D Elements from Model Features
In this step you will create 1D elements from the feature in the model.
