Importing a Medium from File
Import a dielectric, metal or impedance sheet from a .XML file that describes the medium properties.
  1. Select one of the following:
    • Create a dielectric. On the Construct tab, in the Define group, click the  Media icon. From the drop-down list, select the  Dielectric medium icon.
    • Create a metal. On the Construct tab, in the Define group, click the  Media icon. From the drop-down list, select the  Metallic medium icon.
    • Create an impedance sheet. On the Construct tab, in the Define group, click the  Media icon. From the drop-down list, select the  Impedance sheet icon.
  2. Click Import medium from file.
  3. In the Filename field, browse for the file you want to import.
  4. Click Create to import the medium and close the dialog.
