Creating an Impedance Sheet
Define a frequency dependent impedance sheet.
On the Construct tab, in the Define group, click the Media icon. From the drop-down list, select the Impedance sheet icon.
- In the Definition method field, from the drop-down list select Frequency independent.
- In the Real part field, enter a value for the real part of the impedance sheet.
- In the Imaginary field, enter a value for the imaginary part of the impedance sheet.
Specify if the frequency points are manually entered or imported from a file.
Select one of the following:
- To import the frequency points from a file, click Import
points.
- In the Filename field, browse for the file you want to import.
- [Optional] In the Scale by field, enter a value to scale the points.
- Under Delimiter, click the delimiter type you use in your file.
- Click OK to close the Import points dialog.
points.
- In the Label field, enter a unique label for the impedance sheet.
- Click Create to create the impedance sheet and close the dialog.
