Create a frequency-dependent dielectric using the Djordjevic-Sarkar method. Use this method for composite dielectrics.
On the Construct tab, in the Define group, click the Media icon. From the drop-down list, select the Dielectric medium icon.
In the Definition method field, from the drop-down list select Djordjevic-Sarkar.
In the Variation of real permittivity field, enter a
value for Δε.
In the Relative high frequency permittivity field, enter
a value for ε∞.
In the Conductivity (S/m) field, enter a value for σ.
In the Lower limit of angular frequency field, enter a
value for ω1.
In the Upper limit of angular frequency, enter a value
for ω2.
[Optional] Specify the magnetic properties of the
dielectric.
[Optional] In the Mass density
(kg/m^3) field, enter a value for ρ.
In the Label field, enter a
unique label for the dielectric.
Click Create to create the
dielectric and close the dialog.
