Line
Create a line to be used either as a building block for constructing or modifying geometry or as a wire.
On the Construct tab, in the Create curve group, click the  Line icon.
Tip: Press V,1 to use the shortcut key.
Start point (P1) The starting point of the line.
End point (P2) The end point of the line.
