Hyperbolic Arc
Create a hyperbolic arc to be used either as a building block for constructing geometry or as a wire.
Hyperbolic arcs are often used in conjunction with the spin operator to create hyperbolic dishes for reflector antennas.
On the Construct tab, in the Create arc group, click the  Hyperbolic arc icon.
Tip: Press A,3 to use the shortcut key.
Method 1: Base centre, depth, radius, eccentricity
Base centre (C) The centre of the hyperbola on which the arc lies.
Depth (D) The distance from the apex of the hyperbola to the centre of the arc aperture.
Radius (R) The radius of the aperture of the hyperbolic arc.
Eccentricity The eccentricity of the hyperbola on which the hyperbolic arc section lies.
Conditions to create a valid hyperbolic arc:
(1) 1 ε 1 + R 2 D 2
where D is denoted by the depth, R by the aperture radius R and ε the eccentricity.
Method 2: Aperture centre, depth, radius, eccentricity
Aperture centre (C) The centre of the aperture formed by the hyperbolic arc.
Eccentricity The eccentricity of the hyperbola on which the hyperbolic arc section lies. The eccentricity must be greater than one to specify a valid hyperbola.
Note: Not all values greater than one specifies a valid hyperbola.
(2) 1 ε 1 + R 2 D 2
