Elliptic Arc
Create an elliptic arc to be used either as a building block for constructing geometry or as a wire.
On the Construct tab, in the Create arc group, click the  Elliptic arc icon.
Tip: Press A,1 to use the shortcut key.
Method 1: Centre point, radii, start angle, end angle
Centre point (C) The centre of the ellipse on which the arc lies.
Radius (RU) The radius (half of the axis length) in the U axis direction of the ellipse on which the arc lies.
Radius (RV) The radius (half of the axis length) in the V axis direction of the ellipse on which the arc lies.
Start angle (A0) The angle, from the positive U axis direction where the arc begins.
End angle (A1) The angle, from the positive U axis direction where the arc ends
Method 2: V major axis direction - Aperture centre, depth, aperture radius, eccentricity
Aperture centre (C) The centre of the aperture formed by the elliptical arc section.
Depth (D)
The distance from the aperture centre point to the apex of the elliptical arc section.
Aperture radius (R) The radius of the aperture of the elliptic arc.
Eccentricity The eccentricity of the ellipse on which the elliptical arc section lies.
Note: The eccentricity must be less than 1 to specify a valid ellipse.
Conditions for creating a valid elliptic arc:
(1) if   R D : 1 - R 2 D 2 ε < 1
where D is denoted by the depth, R by the aperture radius and ε the eccentricity.
Method 3: U major axis direction - Aperture centre, depth, aperture radius, eccentricity
Figure 1. Method 3
Depth (D)
(2) if   R D : 0 ε 1 - D 2 R 2
