Setting Up POSTFEKO to View Optimisation Progress
Create a 3D view with the far field results as well as two Cartesian graph to view the distance parameter and far field goal.
Display the far field in the 3D view.
Add a Cartesian graph and view the optimised parameter,
alpha.
Duplicate the first graph (to create a second graph) to view the optimised
parameter, d.
- On the 3D View contextual tabs set, on the Display tab, in the Duplicate group, click the Duplicate view icon.
- In the result palette select the trace, Optimisation.
- In the result palette, in the Trace field, select d.
Duplicate the first graph (to create the third graph) and view the far field
goal versus optimisation run number.
- In the result palette, in the Trace field, select serach1.goals.farfieldgoal1.
[Optional] Arrange (tile) the four windows to view the multiple windows at
once.
- On the View tab, in the Window, click the Tile icon.
