Setting the Simulation Frequency
Specify the frequency range of interest.
  1. On the Source/Load tab, in the Settings group, click the  Frequency icon.
A variable was created at the beginning of the example that contains the solution frequency.
  1. In the Frequency (Hz) field, enter freq.
  2. Click OK to close the dialog.
    With the frequency set to freq, the actual frequency is 9 GHz. In the model tree, click the Configuration to view the specified simulation frequency.
